shifter stuck in park!!!!
I really hate for my first post to be a desperate plea for help but......PLEEASE HELP!!
I bought an '04 F-150 Lariat 4x4 supercab w/40k on it last week & love the truck so far except 2 days ago it wouldn't come out of park, there I sat at the drive up window at the bank in my shiny black truck unable to move because the shifter seemed 'locked in place'.
It has the flow through console and floor shifter.
After many repeated attempts it finally shifted into drive. I took it by the dealer I bought it from and of course it wouldn't do it again. Now, it's sunday and I was going to take 'er for a spin with my neighbor and wouldn't you know...it wont come out of park again.....VERY VERY EMBARRASING. I've tried shutting off and restarting the engine, everything I know of to try and still there it sits. Most automatics with a floor shift have an 'emergency' release for the shifter somewhere activated by depressing an indent with a straightned paper clip etc... but I can't locate the telltale small hole anywhere. Any suggestions?
Thanks in advance for any help.....stuck in Wyoming.
Yeah happens every now and then since the early 90s for the safety feature that you need to have the brake pressed to come out of park. If the brake light switch fails the truck thinks your foot isn't on the brake. Other key givaway is the brakelights don't work.
There is a procedure in your manual that you follow a few steps with the key position and such to get out of park due to an electrical failure. Slips my mind at the moment as I would only have to worry bout it for one of the 7 trucks.
Adrianspeeder
Adrianspeeder
Do you know if this can be fixed? This happened to me today. I went to the mall with my wire and noticed when I got out of the car that my left headlight wasnt working. I thought it was wierd. Then we went to leave, and couldnt get the shifter out of park. Gave it a few minutes - then it broke loose.
Now - one point here. I have been attempting an installation of an audio system that hooks to the reverse sensor wire and the speed sensor wire. I also ran a backup camera. Could I have messed something up? Shorted something out?
Yeah - they were off and on too. During my nav installation, I tapped into the reverse wire - and I rechecked that tonight. Lo and behold - didnt quite get the harness back in all the way!
fixed the problem - but boy do I feed STOOPID!
Very interesting the effects of that though - shifter didnt move, left headlight out....
Next time it's stuck, try this. Turn the key from off to the first click. If anything turns on, you went too far. Now move the shifter to N. Start the truck with the shifter in N, and you're fine until you put it back in P.
Jditta,
I am having that same problem right now. The fuse is blowing on mine that controls the Stop Lamp switch, Speed Control, Brake Shift Interlock, ABS, PCM Module inputs, GEM Module.
I can get it to run by turning the ignition to the first setting, then putting it in Neutral and cranking it up. It works but I am not sure what to do. It is either a faulty wire and or by Switch. What is also funny is that my windshield wipers stop working when that fuse goes out so I am at a loss as to where to start.
