F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-03-2006, 08:41 PM
Vehicle: 1997 Ford F150
4r70w direct clutch
This is my first post but I have been reading the forums for a while now.
Please help with Direct Clutch removal...
I have 97 f150 4.2 2wd. I have removed my tranny (4r70w) to hopefully fix the problem of having no 3rd or 4th gear. I have had it tested and looked at before I took it off and every shop said it needed a rebuild. So I decided to take it off myself and check it out.
Everything looks like new so far, except for the direct clutch pack that I can see, but I cant get it out of the tranny. I can see bad wear on it and even the piston above it is caked with nasty fluid that looks more worn then the other fluid.
My question is:
How do I remove the direct clutch? I have removed the tc, pump, the first batch of plates. Now it is just the shaft and the last bunch of gears left ( direct clutch) and it wont pull out. It is very loose and will move around but wont come out. Any help with this would be greatly appreciated. Any advice on replacing this or help with the whole rebuild would be greatly appreciated.
Old 06-11-2006, 01:25 AM
Below is a very detailed info on the 4r70w...
http://www.mn12performance.com/mn12-...rans-tech.html
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
