F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-27-2006, 08:41 PM
Vehicle: 1997 Ford F150
Unhappy Please Help !!!!!!!!!
I have a 2001 Super Crew, 4.6 with the 4r70w transmission.
Today while driving home the speedometer started jumping from 0 - 80 and higher then quit workng all together. The odometer also quit working and went to - - - - - - - - -. The overdrive light in the shift handle started blinking and thats when I noticed that I had no gears. I stopped the truck and started out again slowly. Again no noises were ever heard or clunks etc.
The truck had 1-3 gears but shifted fast and tach out. No overdrive. I was a few miles from a family members home so i attempted to limp it there. I almost made it but hit a red light. When i went to pull out I had no gears again but I manually shifted it into 2nd and was able to make it slowly to a parking space. NO FLUID on ground, no smoke, no check engine codes no noises nothing!!!!!!! And yes I did check the tranny fluid and it was right on.
I'm supposed to leave on vacation, pulling my JUST PURCHASED CAMPER, in three weeks and need to get this thing fixed. If anyone has a clue please let me know. E-mail me direct if you want at mcornell@iup.edu
Old 05-27-2006, 10:16 PM
Vehicle: 2004 Ford F150
Send a message via AIM to Quintin Send a message via Yahoo to Quintin
If the overdrive light was flashing, there should be continous codes stored in memory. That's where I'd start.
'I cannot forgive you. As there are no trustworthy oaths between men and lions, there can be no love between you and me. One or the other must fall before then, to glut with his blood Ares, the god who fights under the shield's guard. Remember every valor of yours, for now the need comes hardest upon you to be a spearman and a bold warrior. There shall be no more escape for you. You will pay in a lump for all those sorrows of my companions you killed in your spear's fury.'
Old 05-27-2006, 11:25 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
And I bet the code points too a VSS, the speed sensor, failure. It's a 30 dollar part on the rear diff you can change yourself in 15 minutes. Any autozone can scan you for free then sell the part if that comes up.
On your truck, the speedo, odo, and tranny shift points, and ABS system use the VSS to tell them how fast the truck is going.
Worst case however is metal bits floating around your rear diff, causing the VSS to read wrong. Metal bits are never a good thing.
Adrianspeeder
Old 05-29-2006, 12:10 AM
Day two.
Went to pick up the truck today. Started it up and the damb thing worked fine. The OD worked and the light was not blinking. Also the speedometer and odometer both worked. I drove it home, about ten miles, and every thing seems fine ??????????????? So what was the problem in the first place. A sensor ?????? Should I take it to a shop anyway? I feel very uncomfortable with taking it on a trip in fear of it breaking down again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
