F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-26-2006, 12:07 AM
Vehicle: 2001 Ford F150
shudder hesitation while in overdrive
I have an 01 SCREW 2WD, 4.6, 82K, tranny requires Mercon V, can't remember what version tranny. I notice a shudder at steady throttle around 40 MPH, or going up a hill at light throttle, or when starting from a stop. When I turn the O/D switch off, these symptoms go away. All fluid changes have been done via flush. I changed the fluid at 36K miles, changed the fluid and filter at 65K miles. Truck currently has 82K miles and the shuddering just started about a week ago (less than 500 miles ago) and has gotten steadily worse.
I have searched this forum for tranny shuddering in overdrive, but none seem to have the same circumstances that I have.
Anyone have a cure?
TIA,
Old 05-26-2006, 09:10 AM
Vehicle: 1997 Ford F150 5.4
It's either torque converter shudder or a light-load misfire.
If indications are that it's the TC, I'd flush the tranny then add a bottle of Lubeguard's Shudder Fix.
If you have a well-capable scanner (the cheaper ones can't do this), look at your misfire count PIDS to see if you're starting to accumulate misfires on one or more cylinders. You can have a certain number before the CEL will be turned on.
Steve
Old 05-28-2006, 07:06 PM
You are one of many to experience this phenomena known as torque converter shudder. As soon as I felt my shudder at 40mph, I took it in for a full service flush with Mercon V. It actually make things worse and it started to shudder all throughout the power band in any gear within a week or two. The Dr. Tranny junk everyone said to add just makes everything feel mushy and may mask the feeling of shudder for a short period of time. From what I've read, it's actually the torque converter that is locking/unlocking. Since I have so many miles on the transmission, I feel like getting the TC replaced without rebuilding the clutches is a waste of time. I am in the process of looking for fully rebuilt transmissions, but I will continue to drive it in the meantime.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
