F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-17-2006, 11:53 PM
Vehicle: 2002 FORD F-150
Transmission Pan Fluid Capacity
I Just Installed A Seperator Plate And Would Like To Know What The Fluid Loss Was About When I Removed The Pan. This Way I Will Be Close When I Refill.
Old 05-18-2006, 03:38 AM
Vehicle: 2002 F150 super crew
You need new Mercon V in any event.
Fil with 4 qts, start the engine, run thru the gears with your foot on the brake, then check the level with the motor running.
If it shows on the dip stick, let the engine run to warm the fluid then check the level again. Add fluid till it reaches to the bottom of the cross-hatch area.
After a road run to get the fluid up to it's normal operating temp fill to near the top of the crosshatch area and you done.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
