Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 05-15-2006, 04:41 PM
Garage is empty, add now
Vehicle: 1999 Ford Expedition
99 Expediton w/ 'LONG' 1-2 shift.
Have a '99 Expedition, 2WD w/ 4.6L and a E4O??? or a 4R70 (not exactly sure) transmission. All of a sudden, w/ no prior drive ability problems, it began missing 2nd gear. 2nd is still there (from a manual standpoint) and does not seem to be slipping.
When cold, for a couple of shifts, it acts as if there is no problem and shifts normally right from 1st to 2nd with no throttle 'manipulation'. After it warms up, it will hold 1st up to about 3000 RPM before shifting into second; occasionally it will require a gradual reduction in throttle pressure to make the shift to second.
When slowing and downshifting, it drops straight form 3rd to 1st, or at least appears to. Under heavy acceleration, from 3rd to what should be 2nd, it acts as if it's thrown into neutral until you release some throttle pressure; but again a manual shift engages 2nd w/ no apparent slippage.
I know this thing has about five or more pressure type solenoids, but was just wondering if these symptoms are indicative of problem w/ a particular solenoid. Help!!!!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
