F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-27-2006, 09:09 PM
Vehicle: 1998 f150
Tranny don't like cold weather
We have had an easy winter this year on Long Island .Cold weather came last week end.4r70w in my 98 4#4 does not like to shift from 2nd to 3third until I drive two or three blocks in cold weather.As truck warms up it shifts fine,normal shift points.Ihave pumped out 3qts. from dip stick tube,added new mercon 5.Too dam coldto dump whole tranny now.truck has 70,000 on it. Any ideas?
Old 02-28-2006, 01:59 AM
Vehicle: 2002 F150 super crew
Ah, it is supposed to work that way.
Thing called a temp sensor prevents OD from working until fluid gets a little warm.
Old 02-28-2006, 09:27 PM
Vehicle: 1998 f150
Bluegrass, I thought the 4r70w was a 4 speed tranny with the OD?
Old 02-28-2006, 10:22 PM
It is a 4 speed but sometimes the shifts hang awhile when the fluid is cold.
It won't engage OD until a certain min warm temp is reached.
I won't say you don't have a problem but if it shifts ok after the engine warms I would not worry to much unless you see a problem when the temp outide rises.
Around here is has gone down to at least 10*. I often see shifts hang in all my trucks and car when driving off in temps that cold.
The trans won't heat very fast just sitting. The fluid has to circulate and be helped along being warmed by the radiatior temp heating the fluid as it runs thru the coolaing lines to and from the radiator and the fluid shear in the converter while driving before lock up into OD.
These all contribute to the whole situation.
Old 02-28-2006, 11:08 PM
Vehicle: 2000 Ford F-250 7.3
Send a message via AIM to Zaairman
I work one block from the highway I take to get home, and at night when it's cold and I jump in and take off, it won't go into OD until I've driven at least a mile.
In Hoc Signo Vinces
Quote:
Originally Posted by RockPick View Post
Having fun as a kid is one thing... being an absolute toolbox is another. You're the latter of that comparison.
God is great, beer is good, and people are crazy
Old 02-28-2006, 11:25 PM
That is correct. The temp sensor keeps the lockup held off until the fluid and trans temp comes up to a min point.
Old 03-03-2006, 11:59 AM
Vehicle: 1997 Tundra I wish :(
Hum.. I was just going to post a thread about this. Seems stupid to me. Average temp is between 5º & 15º in the mornings here from December to March. I drive my F150 to work (about 8 miles) and it never gets hot enough to use the overdrive, end up wasting a lot of gasoline turning 2500 rpm on the highway.
Is there a way to override or alter the setting on the temp. sensor?
Old 03-03-2006, 01:52 PM
Well aside from just thinking it's stupid, there are reasons this this done.
Find away around it and cost yourself lots of money just to save a few pennies on gas.
The fluid viscosity is much higher in cold temps, causes high system pressures and the lockup friction material slips and wears much faster, seals are not as pliable etc.
That enough reasons?
Old 03-03-2006, 02:00 PM
Vehicle: 2002 Ford F150
Quote:
There is a way to change this. Just modify the software that's running the transmission, or write yourself a whole new program.
Old 03-03-2006, 04:19 PM
Vehicle: 2005 Ford F150
Send a message via ICQ to Corpsie Send a message via AIM to Corpsie Send a message via Yahoo to Corpsie
You're barely wasting any extra gasoline by not having the TC locked up when the fluid is cold.
Old 03-05-2006, 12:05 PM
Vehicle: 2001 Ford F-150 4x4
Yep, my 01 with the 4r70w does the same thing like clockwork. I live in Minnesota and it's gotten below zero a few times this winter and it takes up to 4 or 5 miles before the tranny starts shifting smoothly. Drive it nicely and don't accelerate hard until the truck has reached its normal operating temperature.
Old 03-05-2006, 12:13 PM
Vehicle: 1999 Ford F350 7.3l
my diesel does the same thing
like clockwork
tranny MUST be warm to operate correctly
when its REAL cold it will not move untill heat is built up
when the engine temp guage gets to normal then all is well
i have noticed if its 50-60 degrees out then i have no issues with shifting from the get go
...zap!
Old 03-06-2006, 02:05 AM
Vehicle: 1997 Ford F-150
is this true for every trans.?? it could be 0 degrees outside and i can go hop in my 93 T-Bird and as soon as i hit about 42-43 mph it will shift into OD. is my temp sensor out in the bird or what?
Old 03-06-2006, 09:35 AM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Is the 93 tbird electronicly controlled? AOD-E or the AOD
Adrianspeeder
Old 03-07-2006, 01:37 AM
Quote:
Adrianspeeder
lol good question, i have no idea
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
