F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-23-2006, 04:18 PM
Vehicle: 2001 Ford F-150
Changing fluid please help????
i have to change the ranny fluid in my 01 s'crew. 5.4L automatic with od
What tyoe of fluid do i use and how many quarts do i need? thanks
Old 02-23-2006, 04:42 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Look on door jam sticker. U is the 4R70w which needs Mercon V. E is the 4R100 which needs Mercon.
Adrianspeecer
Old 02-23-2006, 08:03 PM
Vehicle: 2005 Ford F150
Send a message via AIM to mkinttrim Send a message via Yahoo to mkinttrim
Man for $129 take it to a tranny shop, have the filter replaced and have it flushed. Less mess, less hassle, .........but more expensive.
Old 02-23-2006, 09:09 PM
Vehicle: 1994 Lightning
Pull the dipstick on the tranny. It will be labelled whether to use Mercon or Mercon V. Usually, it is located on the handle. If not, look near the hash marks on the stick.
Old 02-23-2006, 09:24 PM
how many quarts does it take to change filter and fluid?
I have also seen some fluids that say that they meet the requirements of both mercon and mercon v is it not recomended to use a universal fluid vs the correct one. whats the diff between them
Old 02-23-2006, 11:05 PM
When in doubt, use the fluid recommended by the manufacturer. Personally, I only trust Motorcraft. If you are only dropping the pan, put about 5 quarts back into the trans, start the engine, run through the gears while parked, and check the level. Keep adding until you are within the hash marks on the dipstick. The 4R70W usually only takes maybe 6 quarts, and the 4R100 around 7 to refill. Be sure to recheck the level after everything warms up and you have driven it. Good luck!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
