F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-22-2006, 03:14 PM
pcm calibration problems?
ive tried to fix my truck with help from a few of you but need still more help. it brings up p0708 code. i have replaced the tr sensor, checked the wiring, replaced the pcm. today i found out that the motor and trans were replaced with second hand parts. the replacement parts came out of a 96 model truck with a pcm calibration 6-48d, the pcm in my truck is calibrated to 7-48c. could this be the problem?
my truck is a 97 model. thanks. brian
Old 02-24-2006, 11:22 AM
Vehicle: 1997 Ford F150 5.4
I doubt that the PCM calibration has any effect on the P0708 code.
I'd suspect one of the following:
DTR alignment
Wiring harness issues (open or short circuits)
PCM fault
Other sensor/wiring/PCM fault that kills needed signals
You really need an OBDII scanner capable of reading and displaying PIDS to see what the PCM is seeing from the DTR. You can manually duplicate this testing with a meter, but the procedure is more difficult since you'd be stabbing at connecxtor pins with a probe.
Hopefully, you also have access to the factory service procedure from the service manual or CD. It is a definite requirement.
Steve
Old 02-25-2006, 08:24 PM
Vehicle: 2004 Ford F150
Send a message via AIM to Quintin Send a message via Yahoo to Quintin
I'd take a close look at the pins on the connector to the MLP. I've had 'em before where the individual pins spread and make poor/intermittent contact with the MLP itself.
'I cannot forgive you. As there are no trustworthy oaths between men and lions, there can be no love between you and me. One or the other must fall before then, to glut with his blood Ares, the god who fights under the shield's guard. Remember every valor of yours, for now the need comes hardest upon you to be a spearman and a bold warrior. There shall be no more escape for you. You will pay in a lump for all those sorrows of my companions you killed in your spear's fury.'
Old 03-06-2006, 04:00 PM
fixed it
just in case this may help out anyone else- i put the new module (pcm) and it has fixed it. i suspect the type of tr sensors changed between the time of manufacture of the trannys and so the truck required the original module to operate properly. so if a p0708 code comes up and its not the sensor or the wiring it may be a pcm - but there are probably unusual circumstances for it to be so. thanks for all who helped. brian
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
