F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-15-2006, 08:11 PM
trans fluid change
i have a 2000 f150, 4.6 auto trans. how often should i change the filter and fluid? also, i still have the original battery. next mont it will be six years old.
Old 02-15-2006, 09:44 PM
Vehicle: 1985 Ford F150
I would do it every 30,000 just to be sure down the road the tranny will probably be the last thing to go out.
Old 02-21-2006, 08:28 PM
50,000 miles on the tranny fluid/filter unless you pull heavy load often. I would consider that you have been quite lucky having the original battery last over 6 years. If you don't go to far from home, I would see how much more you can get out of it and save the $$$. If you travel longer distances or are out of town often, I wouldn't chance it.
Old 02-25-2006, 10:34 AM
Vehicle: 2001 Ford F-150
Talking
i change mine every 25,000. I figure it is cheeper to change the fluid than it is to repair. Maintenance is key to keeping any truck running good.
Old 02-25-2006, 06:31 PM
Quote:
how often should i change the filter and fluid, next month it will be six years old
answer: Yesterday
Old 03-02-2006, 08:43 PM
Vehicle: 2002 Ford F-150
I change my tranny fluid every 30k. That way I don't worry about "flushing" all of the fluid out. If the fluid starts to look or smell dark or "burnt" when you check the level, change it more completely and/or more often.
Batterys tend to die around the 4 to 5 year mark. If it's still cranking strong, good for you! Just keep an eye on it.
Old 03-07-2006, 04:22 PM
Vehicle: 1997 FORD F150XLT
If a fellow goes and gets one of them 79 dollar flush/purge or what ever they are called for our transmissions. Do they have differant types of fluid? or Is it a all for one type deal. Because im sure when I asked a local qwik lube they said they use a fluid that works for all types.
Old 03-07-2006, 05:46 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
The E4OD (before 99) and the 4R100 (after 99) have a trans code E on the door jam sticker. Use Mercon.
The 4R70w (trans code U on the door jam sticker) uses Mercon V.
Please look and post what you have. Also MAKE the tranny place use Mercon V if you have the 4R70w, and BE SURE not to let them use a Mercon V or blend if you have the 4R100.
Adrianspeeder
Old 03-08-2006, 09:52 AM
1997 4.6 4X4
under the letters TR on my door jam. it says "U"
Old 03-08-2006, 11:38 AM
Vehicle: 2002 Ford F150
Quote:
Originally Posted by MONGONGO
"U"
4R70W. Use MERCON V.
There are instructions here:
http://www.ford-trucks.com/article/i...nsmission.html
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
