Gear ratios...? - F150online Forums
Gear ratios...?
Old 12-23-2005, 10:38 PM
Gear ratios...?
What are the actual ratios for each of the 6 gears on a '04 5.4L 3:55 r/e?
Old 12-24-2005, 10:13 AM
You only have 4 gears.
1st. 2.84
2nd I don't remember
3rd 1
4th .7
Old 12-24-2005, 02:21 PM
adrianspeeder's Avatar
You have four forwards and a reverse so thats five gears. Haven't been following the new trucks too close to see what comes with what, but either tranny have the same ratios. Info from this post...
http://www.f150online.com/forums/sho...60#post1832360
Model: 4R70w
Type: Four speed + reverse and 70(x10)lbs of torque
Years: 94-96 Bronco, F150
..........97-02 Expedition, F150
..........04-06 F150
Engines: 300, 302, 4.2L, 4.6L, 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: U ('94-'03), A ('04-'06)
Model: 4R75E
Type: Four speed + reverse and 75(x10)lbs of torque
Years: 04-06 F150/ Mark LT
Engines: 5.4L
Fluid: ?
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06), F ('06 Mark LT)
Adrianspeeder
Old 12-25-2005, 10:09 AM
Thanks for the transmision info. Now, I have a novice question about rear-axle gear ratios. I understand that the trans gear ratio is the ratio of engine RPM to drive shaft rpm. In a rear axle, what is the meaning of 3:55 (my FX)? I noticed there are many axle options, 3:75, 4:10, etc. :santa:
Old 12-25-2005, 10:20 AM
It's the ratio of the driveshaft RPM to the axle RPM. 3.55:1 means the driveshaft will rotate 3.55 times for every rotation of the axle.
Old 12-25-2005, 11:27 AM
Yup what he said.
A lower number is a "taller" gear giving better highway milage, and a higher number is a "deeper" gear giving more off the line grunt.
Adrianspeeder
Related Topics
Thread
Forum
Replies
Last Post
02xltscab
Introduction Forum
5
11-06-2015 09:23 PM
BryanPaDo
V8 Engines
3
11-05-2015 08:18 PM
SSGT_B
Transmissions
1
10-05-2015 04:08 AM
DPReal
10-01-2015 03:01 AM
Bubbadewsky
Trucks For Sale (1997 - 2003)
0
09-29-2015 03:08 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
