My friend you have a hydrolic clutch problem. The clear fluid was likely the dot 3 brake fluid used in the hydrolic system. Either it is the slave has died or the master cylinder. Most likely the slave cylinder gave it up. There may be a deeper problem though. Sorta sound like you have spun the center out of the clutch disk as well. Had a friend do the same thing on a chevy. Either way, pull the inspection plate and take a look. You will probably be able to see if something catastrophic has happend but other wise you are likely looking at pulling the tranny to do a clutch job unless of course it is the master cylinder.
Anyway, hope that helps.
2001 F-150 Supercab 4.6 4x4
Limited Slip
Nasta Stainless Nerf Bars
Bug Shield
235/70/16 BFG LongTrails
Autometer Traditional Chrome
Water Temp.
Trans. Temp.
Oil Pressure
Voltmeter
Check out my Gallery
