F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-06-2005, 10:12 AM
Vehicle: 1998 Ford F150
Send a message via ICQ to F150_Sweden
Shifting while overtaking.
I have a 1998 F-150 XLT 2WD with 4.6L engine with 180.000 miles on it.
And i guess I have the 4R70W
When overtaking the transmission kicks down, but will not engage the next gear at high rev. unless i step of the gas a little bit (then the turbine gives you a REAL kick)
Reading in this forum i have found out that this problem probably could be solved installing a B&M shift improver kit, specially since the tranny has a couple of miles on it.
Correct me if i'm wrong.
Old 12-06-2005, 11:34 AM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
On your door jam sticker...
U is the 4R70w
E is the E4OD/4R100
Old 12-08-2005, 10:01 AM
I would really like to know what you guys think.
What is the problem with my tranny, and does a shift improver kit solve my problem?
Old 12-08-2005, 11:36 AM
Vehicle: 2001 Ford F-150
Send a message via AIM to WVtrucker
I think adrian was fishing for which tranny you have. It would help in the diagnosis as there are fairly extensive differences between the two.
2001 F-150 Supercab 4.6 4x4
Limited Slip
Nasta Stainless Nerf Bars
Bug Shield
235/70/16 BFG LongTrails
Autometer Traditional Chrome
Water Temp.
Trans. Temp.
Oil Pressure
Voltmeter
Check out my Gallery
Old 12-08-2005, 11:44 AM
What tranny do you have
Adrianspeeder
Old 12-08-2005, 11:57 AM
Vehicle: 2002 Ford F150
The only auto that was available in '98 with the 4.6L was the 4R70W.
Old 12-08-2005, 03:13 PM
Been through this before, I have seen late 98s with the 4R100. Small chance he has one, but any advice would suck if he did.
Adrianspeeder
Old 12-19-2005, 11:46 AM
Ok found out today. (the car has been at the paint shop)
The sticker on the door says:
trn
U
So I have the 4R70w
Old 12-19-2005, 08:14 PM
Vehicle: 1997 Ford F150
mine used to hold the lower gear if i had it on the floor for a long time, once i let off it would upshift. the shift improver kit did "fix" it..... i think. it still holds the low gear until i start to let off the gas pedal but not like it used to where i had to let go of the gas completely.
i'm not really sure if it's actually a problem to being with. i think it's a built-in gaurd for o/d because aparently it's a pretty weak band in the transmission. high power shifting puts alot of stress on it so the computer says no shifting until the rpm's come down a little along with closing the throttle a little.
all i can say is the shift kit was definitely worth it either way.
Drive a hybrid, I need your gas.
'97 f150 supercab 4x4 off road 4.6
full dual flowmasters
b&m stage 1 shift kit
4.56 ls gears
315-70-17 bfg a/t's
torsion bars cranked all the way up
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
