F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-02-2005, 04:37 PM
Manual Transmission queston
I have a 95 F150, about 186,000 miles. Clutch replaced less than 2 years ago. About 10 – 12 months ago was having trouble shifting into gear. Clutch had to be pressed all the way to the floor to disengage. Had the transmission serviced and bled. Was told that I may have to have master cylinder replaced. Same thing is happening again, but being that it is Christmas time, don’t really have that kind of dough laying around. Can I add fluid to the transmission? Where do I add fluid? What kind of fluid? Just looking for a band-aid solution to buy me a month or two.
Old 12-02-2005, 07:42 PM
Vehicle: 1999 Ford F150
On my 99 there is a little plastic resevoir screwed to my fire wall, near the mastercylinder. It taked dot 3 break fluid. if there is air in the line then you will have to bleed the system.
Old 12-05-2005, 11:59 AM
Vehicle: 1997 Ford F-250 LD
Yes, the hydraulic clutch uses regular brake fluid. The reservoir is mounted next to the brake master cylinder. If the it is bad ti's a simple swap. No idea how much it costs to replace but it can't too much.
If you pump the peddle a couple time before shifting, is it easier?
If so, then the clutch master cylinder is bad.
Bleeding the system is a two person job. Just be sure to keep the fluid topped off.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
