My OD light started flashing last week, have since put about 500 miles on truck. Seems to work fine. When shut off and restarted, sometimed it comes on, other times it doesn't. Any ideas??
Haven't done a thing, as far as fluids go. But I did have a leak that went away, from the rear seal @ tailshaft, in front of rear driveshaft front u-joint. And yes, I did check fluid levels to make sure the leak didn't stop 'cause it was run out of fluid!!!
Mine is having the same problem. I cant stay in overdrive, and when the OD light starts blinking the trans goes crazy. After awhile the OD light will quit blinking and the trans will be OK until I get to about 50 mph and then it wants to search between 3rd and OD. What did they tell you? I thought it might have been a prob w/ my shift kit.
1995 F-150 4x4 XLT - 6" Skyjacker Softride lift, 35x12.50 Dunlop Mud Rovers, 15x10 American Racing rims, 4.10 gears, detroit lockers, custom ladder bars, 351 V8, airraid intake, E40D auto trans with B&M Shift Kit, dual 3" exhaust
1999 f 150 supercab 4x4 48,000 miles,, started blinking last week on wed and thur,, dropped it off at Dealership on Fri,, bad accumulator pistons, 1-2 and 2-3,, Im pretty sure if your light is blinking,, it could be anything, its just storing a code of the problem.. def would get it checked out,, could save you from a more costly repair later
