F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 11-30-2005, 12:45 PM
Vehicle: 1998 Ford F150
Ok. I'm dumb, but please answer...
This is going to sound like a retard question, but here it goes: How do I know when the TC has locked up? 90% of mr expirience is with standards, I'm not to much on autos. As a matter of fact, this is the first automatic I've ever owned. My wife has hers, of course, but I've never owned one until now. Also, how hard is it to install a tranny oil temp gauge?
Old 11-30-2005, 12:54 PM
Vehicle: 2002 Ford F150
It can be hard to notice when it locks.
When in third or fourth gear you may notice what seems like half a shift. That's the torque converter locking. When driving at a steady 50 MPH lift off of the throttle. Then go back into the throttle to the same place to maintain your speed. You'll notice the engine speed goes up a few hundred RPM when you went back on the throttle, then settles back down. When it drops the torque converter locked.
Old 11-30-2005, 12:59 PM
Is that the samething that they call 1:1 lockout? My dad told me to test it by cruising ~55, and lightly touching the brakes. The rpm's should come up a little. But I thought that was a function of the tranny, not the TC.
Old 11-30-2005, 01:04 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
If you feel real close you can hear a little mini shift in third or fourth gear. This can also be seen with a 100 or so rpm drop.
Read up on this.
http://auto.howstuffworks.com/torque-converter1.htm
Adrianspeeder
Old 11-30-2005, 02:03 PM
Vehicle: 1997 Ford F150
The way I can tell is if I'm at a steady speed in whatever gear the trans is in. Really, the only time I notice I'm unlocked is when I'm going up a hill.....
Lets say I'm pulling a hill at 30 mph, so I'm in 2nd gear. I can tell if it's locked or not by giving it a bit more gas. If the rpm's instanly rise, the TC is unlocked. If there is no quick rise in rpms and you don't really gain any speed, then it is locked.
The same is true when I'm in 3rd and going around 40 mph. I can do the same thing and get the same results.
If you press too much on the gas, then that will usually trigger a downshift or you will 'feel' the TC unlock (it'll kinda feel like a downshift, but just not as intense) You will know when you have downshifted from 3rd to 2nd by the instant rise in about 1000 rpms!
When I'm in OD (4th), I have yet to feel or see any unlocking of the TC..... If I give it gas while in 4th, I will either trigger a full downshift into 3rd or I will gradually pick up speed with the rpms rising in time with the gain in speed.....
While towing, I'm almost never in 4th and it does not take much for it to downshift on it's own anyway. That's when I just lock out OD and run in 3rd. It will stay in locked third pretty much the whole time. If I encounter a hill, I have to press the gas pedal enough that it always triggers a full downshift into 2nd. I can then 'feel' and see the rpms drop some when it does lock in 2nd. I also manually pull the gear shifter into 2nd to hold that gear for as long as I'm still going up the hill. If I am gaining speed and it's in D, then it will want to shift into unlocked 3rd while still climbing the hill. I prefer to just let it hold 2nd until I get to the top.
Probably more then you wanted to know, but that's just been my experience with it..
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 207,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 11-30-2005, 02:35 PM
Vehicle: 2009 Ford F150
One way I can tell if the TC is locked is to look at my tach. If in OD with the TC unlocked and I give it gas, the tach will move up quite a bit. If locked, the tach will just move as I speed up, barely any movement. The best time to see the TC unlocked is on a cold morning, the first half mile or so, when in OD the RPM moves with the throttle. Once locked, it moves with the speed.
Old 11-30-2005, 02:47 PM
Adrian, I found that website a while back, just never looked a TC's on it... But damn, I love that website. All of us here pretty much either fall into the catagory of professional mechanics or shade-tree mechanics. How many of you have ever disassembled your wifes vacuum to fix it, just so you don't have to buy her another one. The thought of spending money, that I could spend on my truck or quad, on a vacuum makes me shudder...
Old 12-01-2005, 01:56 PM
Vehicle: 2001 Ford F-150
Send a message via AIM to WVtrucker
Diddo on watching the tach.
2001 F-150 Supercab 4.6 4x4
Limited Slip
Nasta Stainless Nerf Bars
Bug Shield
235/70/16 BFG LongTrails
Autometer Traditional Chrome
Water Temp.
Trans. Temp.
Oil Pressure
Voltmeter
Check out my Gallery
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
