F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 11-25-2005, 01:13 AM
Can a 4R70W be swapped out for a AODE?
Hi, I have a 1995 Ford F150 XLT, it has a 5.0, and a 4R70W.
The transmission has crapped out on me. the O/D light flashes, it shakes, and leaks fluid like mad out of the tailshaft housing. I am going to replace the trans, or have it rebuilt. It occured to me that mated up to my 5.0 HO engine in my garage, is a AOD out of a 1988 Lincoln Mark Vii LSC. I got the motor last week for my 1965 mustang, and the mustang currently has a T-5 mated to its 289. I was about to post the AODE for sale when it occured to me that I could run this tranny in my truck. My question is i have spent NO time researching this and know I could make it work, but is this a bad idea? What issues would i run into? is the tranny just too weak to even consider using? Any info will help. I imagine im going to go with plan A and replace/rebuild the 4R70W, but I thought before i scrapped the AOD, id see if it could be usefull. - I understand that im taking a step back with technoligy, but is there any big downfall of going from the Electronic shift to the vaccum shift? Thanks
-Jacob
Old 11-25-2005, 04:03 PM
Vehicle: 2002 F150 super crew
First, the PCM is expecting to communicate with an AODE/4r70w that is not there. Codes right away.
Second, you will need a TV cable or linkage to operate the trans pump pressure vs throttle opening. Extremely important.
Third, the mounting won't be quite the same at the cross member.
Forth, drive shaft length.
Not worth the work and issues IMO.
Replace the 4R70W and be done with it.
Old 11-25-2005, 11:08 PM
Vehicle: 2004 Ford F150
Send a message via AIM to Quintin Send a message via Yahoo to Quintin
IIRC, AOD-E uses the OSS to run the speedometer, the 4R70W uses the TSS, or vice versa, so you might not have a working speedometer after all this either. Find another 4R70W before you cause yourself more troubles than you wanted.
'I cannot forgive you. As there are no trustworthy oaths between men and lions, there can be no love between you and me. One or the other must fall before then, to glut with his blood Ares, the god who fights under the shield's guard. Remember every valor of yours, for now the need comes hardest upon you to be a spearman and a bold warrior. There shall be no more escape for you. You will pay in a lump for all those sorrows of my companions you killed in your spear's fury.'
Old 11-27-2005, 07:19 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
Quote:
Not true at all. The aod/e is a 4r70w with the same gear ratios as a aod. There are other subtle differences,but that is the biggest.
Alan
Old 11-27-2005, 09:47 PM
Might be different years of the 4R70W doing that then. My mistake.
Old 11-29-2005, 11:34 AM
Vehicle: 2001 Ford F-150
Send a message via AIM to WVtrucker
My limited experience with the AOD would suggest that you really don't want to do that to your self.
2001 F-150 Supercab 4.6 4x4
Limited Slip
Nasta Stainless Nerf Bars
Bug Shield
235/70/16 BFG LongTrails
Autometer Traditional Chrome
Water Temp.
Trans. Temp.
Oil Pressure
Voltmeter
Check out my Gallery
Old 12-02-2005, 02:45 PM
Vehicle: 2000 Ford F-150
Send a message via AIM to Red00Lariat
Stick with the 4R70W, its a better tranny IMO.
2000 Chestnut Lariat 4x4 SCab, Rhino liner, Rancho RS 9000x's, EBC pads, EBC sloted rotors 20% tint, AEM Brute Force intake, Magnaflow exhaust, hi flow cats, y-pipe,& headers, SCT 9100 w/Troyer tunes, 180 degree t-stat, walbro 255 pump, 24lb injectors, Lightning MAF, ported TB & elbow, NGK TR5's, and pulleys.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
