F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
  #31
Old 03-01-2008, 02:03 PM
Vehicle: 2007 Ford F150
I had the same problem about three weeks ago. I have a 2007 Screw that I took delivery of in Dec 2006. It happened twice on one trip downtown. The only difference my truck started missing or rough idle at the same time. Like a vac hose had come off or something. I parked it at work and when I drove it home and to the dealer, no problem.
I printed this thread and took it in and talked to the service manager. They were very familiar with the IWE soleniod failures. He checked and said I had the updated IWE (all 2007 should) so he wanted to replace some solenoid or vac device on the axels? He said there was one on each side but only had one in stock, so he replaced the one. They did a very good check out of the vehicle (about 3 hours with truck in bay) and they seemed to know what to look for with this problem.
It has not come back as of yet. So maybe that was it. I just wanted to document it is still happening on 2007 trucks....
Will update if anything changes.
Thanks,
Gary
  #32
Old 07-11-2008, 05:53 AM
(6/13/08) Here is an update, about 3 months later the grinding noise problem came back. They replaced the other actuator (this time the LF) 7L1Z-3C247-A and sent me on my way, the next day it happened again.
This time they replaced valve part number 6L3Z-9E441-A, which they called a solenoid (IWE I assume) and the service manager told me that even though I had the updated solenoid that Ford had redesigned the rain shield on it again (since the 2006 recall). So this exact problem can happen on 2007s, even though there was an updated IWE on my truck. He told me the solenoid was obviously bad and had water damage.
7/11/2008 - As I write this the problem has not returned.
2007 Ford F150 Super Crew XLT....Ordered just the way I like it.
  #33
Old 07-11-2008, 01:23 PM
Vehicle: 2006 Ford F-150
Send a message via AIM to scott1981
Looks like I am going to be picking up one of those IWE soleniods myself and installing it as I am having this issue and out of the 3/36 warranty
  #34
Old 07-28-2008, 11:43 AM
Vehicle: 2005 Ford F150
How do you get the dealer to do the work for you without them hearing the sound? I brought mine in this morning, and they service guy said they can't get it to make the sound so they can't change anything. I told him that it's an intermittent problem, and doesn't happen all the time. They could drive the truck all day and never hear it, but then when I'm driving to work tomorrow it'll happen the whole ride. He said there's nothing they can do. Why can't I find a decent dealership?
Another question, how difficult is it to replace this part? Is there anything overly complex about it?
  #35
Old 07-29-2008, 10:30 AM
Vehicle: 2004 F150
Try giving the dealer a copy of this thread, including the TSB#. Worked for me.
  #36
Old 07-29-2008, 10:36 AM
Did that and they wouldn't listen. I guess I'm trying to find another dealership.
  #37
Old 08-04-2008, 09:53 PM
I also have the same sound, just found a vac leak tonight..... Will that cause the problem ?????
  #38
Old 08-04-2008, 10:24 PM
Vehicle: 2004 Ford F150
Quote:
Def yes!
http://www.youtube.com/GetStuk
Newly Installed:
Amp Research PowerSteps
Pioneer Avic-Z1
Dual Headrest Monitors
Bluetooth, Sirius, Night Vision Backup Camera, and
CA-670 Remote Start/Alarm
more!
  #39
Old 09-30-2008, 03:18 PM
Vehicle: 2006 Ford F150
thank you
just want to thank everybody for posting about this issue - i found this thread easily when i googled! i just started having it too - 06 F150 with 34k miles on it. I'm printing out this thread and bringing in to the dealership with me tomorrow.
i compared the noise to dragging a metal grocery card down the street - that's seriously what i thought it was especially considering i was on my way home from the grocery store!
i hope they can resolve it. the noise freaks me the f* out!
  #40
Old 10-17-2008, 05:27 PM
Quote:
Originally Posted by dmac5356 View Post
I had the exact same problem in my 2005 with only 8,000 miles. Grinding noise from the front. A slight let-off on the throttle seemed to help initiate it. Can temporarily eliminate the noise by shifting into 4HI, then back to 2WD. Problem was a bad vacume hose to the front axle. It was trying to engage the front hubs while in 2WD. The grinding causes collateral damage in the front hubs. All fixed under warranty.
Hi....I have this problem with grinding noise...Dealer can't find the problem. And he is
2 hours away no less! Did you come to some resolution...If so, what fixed the problem.
My truck is a F-150 2006 with ONLY 23,000 miles on it.
Thanks.
Lloyd
  #41
Old 10-17-2008, 06:05 PM
Vehicle: 2004 F150
In my case, it was the IWE solenoid. Mine's an 04, but I've heard of newer F-150s with the same problem. Print this thread for the dealer - it's a well known problem.
  #42
Old 10-19-2008, 11:30 PM
Grinding noise at 55 mph
I have this problem too, i replace the 6L3Z-9E441-A selonoid w ith a cover on top, but it does the same sound again one time. I was mad cause there is so many people here that the problem was fixed. So the only question i have, is it possible that i have water in line, oe the selonoid is defect..
Thanks in advance
  #43
Old 10-20-2008, 12:05 AM
where exactly is this solenoid located?
2007 Ford F-150 King Ranch 4x4, 2" A/S, BFG 285/55R20s, JL Audio TR570-CXi, Weathertechs, Passport 9500i, NFab LB 4x PIAA 520s, Bilstein 5100s in rear
2009 Lincoln MKX
2006 GMC Sierra 2500HD 2WD LBZ, Banks Six-Gun, Magnaflow 4", Banks RAM-AIR, Full Cognito suspension, Weathertechs
2007 Honda CR-V EL-X 4WD
2004 Chevy 3500 Duramax Dually 4x4
1997 Chevy 1500 Suburban 2WD
  #44
Old 10-20-2008, 12:06 AM
Josiah was yours shorting out because water was dripping on the solenoid or do you have a bad or frayed wire?
2009 Lincoln MKX
  #45
Old 10-22-2008, 06:31 PM
We had this same problem. 2006 F-150 4x4..Only 23,000 miles. Our Ford dealership closed
down so had to drive 2 1/2 hours. I gave the dealer the info I found on line here that all
of you had written about..Good thing I printed the info out, cause our dealer had NO CLUE!
Any way, it looks like the Solenoid bad and had no vacuum going thru it which caused the
transfer case to want to go into a different gear!!!! They replaced it....That was Monday,
so we are good SO FAR. Thanks to this website we might have solved the problem. Ford
has no recall on it..We feel that they should. Called Ford Motor Co. They cannot put any TSB's out until they get enough dealers to advise them of the problem. Go figure!
Lloyd
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
