For disscussion purposes the trans is in lockup during this time so the rpm won't suddenly drop just because you lift the throttle but go down as the truck's speed slows. This is because the engine is in hard coupling to the trans with no converter to slip under those conditions.
There is no down shifting unless the speed drops down under about 50 where reapplication of throttle would cause a down shift to occurr depending on the engine load the PCM sees.
Technically if you watch real close the engine tach if you have one, you may see it move very sleightly with throttle lift because it very quickly releases and reapplies the lock up as a normal function. Even tapping the brake will do the same action. There is a reason why this happens but not for this discussion.
