by the time you did all that work, it'd probably be cheaper to sell your truck and buy one that is manual transmission. Depending on the truck you have, it would involve a lot more then just takign oen out, putting antoher one in... i.e. shifter changes, computer changes, adapters to transfer cases if its 4-wheel drive, changes to where it connects to the engine via flywheels, etc.
Do a search on car-parts .com and look up the parts that you will need. You will need a tranny, flywheel, clutch, drive shaft, tranny mount, pedal assy with clutch pedal, complete clutch hydraulic system, and a chip to turn off the automatic tranny controls. You will need to cut out a hole in the floor for the shifter and in the firewall for the clutch master cylinder. it can be done but it would be a major PITA.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
