F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-12-2005, 10:51 PM
Vehicle: 2000 Ford F-150
Troyer's Tranny Stuffs
I was looking at Troyer's site and was curious about some of his stuff for these transmissions. Anyone have any experience with things like the Transgo Shift Kit? How do they work, are they easy to install, how's the performance, ect? Thanks!
Old 08-13-2005, 12:22 PM
Vehicle: 2001 ford f150
I installed the Factory tech valve body easy install and shift great.
Powerdyne supercharger over driven 12# boost
928 Motor Sports Billet impeller
Vortech after-cooler
lightning heat-exchanger and pump
42# Ford racing injectors
Troyer tuned
90mm mass air
Troyer Electric fans
255lph fuel pump
Denso iridium plugs
Water/methanol injection by BE Cooling
Factory Tech valve body
MagnaFlow exhaust
Harley ins. cluster
Bed Rug
bell tech lowering kit
Old 08-13-2005, 02:04 PM
How does it improve accelleration? That's really what I'm looking for. I want some mods for my truck (engine, tranny, gears) that will give me tire spinning accel.
Old 08-14-2005, 04:21 PM
Mine definatly turns the tires on the one/two shift any time you are much past half throttle, all shifts are very quick.
Old 08-14-2005, 07:01 PM
How difficult was it to install? Did you have to remove the tranny?
Old 08-14-2005, 09:29 PM
Vehicle: 2005 Ford F150
Valve body is inside of the tranny pan....unbolt the pan and there it is. Like he said easy, although a bit messy.
Old 08-16-2005, 01:12 PM
Vehicle: 2003 Ford F-150
Quote:
factory tech valve bodywas the easest install of any shift kit i have ever put in all the work is done for you already, all you do is drop the pan unbolt the stock valve body take out springs and reinstall with new springs and valve body, very easy comes with good instruction too, good luck
03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
Old 08-16-2005, 07:49 PM
That sounds pretty good. How is it with towing things? I do want performance, but I also do occasional towing.
Old 08-16-2005, 08:38 PM
the 1-2 shift can be kinda harsh towing you just have to learn to give it the right amount of throttle (or let off at the right time) to keep the 1-2 shif from jerking, but other than that it is fine i have only towed about 3500 with the shift kit but it did great shifts were good, the heaver the load the less the 1-2 shift kicks if you know what i mean, good luck
Old 08-17-2005, 06:11 PM
As big truck311 states install is simple, If you go with a Troyer tune he can soften up that 1/2 shift at ligh throttle and leave it hard at higher speeds or you can leave out the second 1/2 accumalter spring and lighten the shift It can be easily changed when you drop you're pan put a drain plug in it and then if you want to do anything the fluid can be drained easily and saved.
it will be great for towing it drops the trans temperature because you have mor posative shifts less slippage less heat.
Old 08-18-2005, 06:29 PM
Thanks guys. I will probably get something from Troyer. Right now with college it's pretty hard to get anything... even gas at the prices they are now. But when I decide to do something I'll definatly post! Thanks again!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
