F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-07-2005, 10:41 PM
Vehicle: 2003 Ford F150
transmission trouble, Help!
I installed the ftvb the other day, long story but accidently took out the wrong valve body. The checkballs fell. I found a diagram and put everything back and it worked great. The new valve body shifted the lightning very hard, felt real nice. While racing a GMC Typhoon the truck died after hitting red line at WOT. Now it won't shift out of first gear unless I left off of the gas. Also, the overdrive switch wasn't working, turned out to be just a fuse, replaced and overdrive switch works fine. Any ideas on what might be wrong would be very helpful.
Mike
Old 08-09-2005, 12:41 AM
Vehicle: 2001 Ford F150
Could be a stuck shift valve or an accumulator valve. Did you torque the valve body bolts to spec? You could also have a more serious problem such as a seized intermediate sprag or burned intermediate clutches. Have you checked for codes yet?
Old 08-09-2005, 07:32 PM
The check engine light is not on, so I have not checked for codes. Everything has been tourqued to factory specs, checked twice. The stuck valve is what I am praying for, but we shall see.
Old 08-10-2005, 09:34 PM
Turned out to be the ftvb that i ordered. They took it out and now it runs great. good news to hear, considering I thought the tranny was shot.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
