F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-05-2005, 04:16 PM
Vehicle: 1995 Ford F150
Send a message via AIM to UrbanCowboy Send a message via Yahoo to UrbanCowboy
Trouble with 1st gear
My truck is having issues. Anyway, I'm having trouble shifting into First. It goes but I have to force it almost all the time. Pumping the clutch has no effect. Most the other gears work alright but sometimes they stick when I try to shift Out of gear. Its a manual tranny. When I get frustrated at it; I just start off the line in second gear and avoid 1st all together. Unfortunately, I'm going four-wheeling this weekend and will be using the low gears a lot. Am I going to make anything worse by using the transmission in this state? Do you think it's the clutch at all? There's no sign of any clutch fluid leakage in the master or slave cylinders. Any comments would be appreciated.
1995 F150 4.9L I6 Stupid Mazda manual transmission
Quote:
Originally Posted by vader716
In truth UC is right
Old 08-05-2005, 09:24 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Current milage and milage of the last fluid change?
Adrianspeeder
Old 08-06-2005, 12:15 AM
Vehicle: 2001 Ford F-150
Send a message via AIM to WVtrucker
If I were to guess and this would be a guess, I would look at the clutch. With that many years, there are probably a lot of miles on the clutch. Do you have trouble with reverse too? Classic signs of a worn out clutch are trouble with first and reverse. A fluid change is not a bad idea if you haven't done one in a while.
Good luck.
2001 F-150 Supercab 4.6 4x4
Limited Slip
Nasta Stainless Nerf Bars
Bug Shield
235/70/16 BFG LongTrails
Autometer Traditional Chrome
Water Temp.
Trans. Temp.
Oil Pressure
Voltmeter
Check out my Gallery
Old 08-06-2005, 07:41 AM
Another vote for check the clutch, sounds like it might not be fully releasing.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
