F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-02-2005, 10:33 AM
Vehicle: 1999 Ford F150
Question Something wrong with the trans. shifter!!!
Today when I was parking my truck at work, changing the trans. shifter to reverse and the stick was "free wheel"!!! It didn't change to no shift !!!(P-R-N-D-2-1) stayed at drive. I can not park because It didn't change to reverse. I didn't turn it off, bc at drive only is not possible tu turn it off!!!
What a big problem... I decided to go back to my home without turning the engine off. But suddenly it started to work but now park is in reverse position, reverse is on neutral pos., neutral is in drive .... everything is shifted.
I left the truck in the parking and tonight I will try to fix it.
What I need to know is if there is any hint !!
this happens to anyone on this forum?
Need Help
benjjie
Old 08-17-2005, 11:53 PM
This may come a little late, but i have had trouble with the same thing, only not a severe. When i would shift the pointer would be in a certain position, and the actual cable another. I checked under the dash and discovered several loose screws which atach the cable to the shifter linkage. after tightening them up, i had no more problems. The shifter linkage would lock into say, the neutral position, and since the cable wasent firmly attached to the linkage, the tranny would not move from drive.
Hope this helps!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
