New update 5/6/06.
Mac alum pan installed with mechanical temp gage.
Begin recording operating temperatures in regular nontowing driving conditions.
We begin towing in about a week.
Pan install notes:
On a super crew there is an exhaust mounting included with the rear trans mount that takes up room needed to get the pan in place.
The solution is to remove about 1/8" across the back pan flange. There is lots of meat to be able to do this.
Suggest the pan be drilled and tapped for plugs so a temp gage can be installed at any time.
The original magnet ring from the stock steel pan is put on one post in the new pan. These two posts are the supports that keep the filter in place.
So far the highest pan temp has been 140 at the same time the converter temp was at 145.
The major difference so far has been the longer time it takes for the pan temp to rise. This can be a small problem in winter weather not using the radiator cooler in the line to create a min. floor operating temp.
To refresh, trans is a 4r70w, 4.6 engine, 3.55 gears. Using a conveter output temp gage, two aux coolers in line, no radiator cooling, and a deep alum pan with it's own gage. Data collected with an infrared heat gun as well as the gages for compairson.
Next update after some runs under actual load conditions of nearly 12,000 lbs gross combined weight in warmer temps..
