F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-17-2005, 12:07 PM
Clutch Reservoir fluid fill
I have a 95 XLT 4x2 and I am having some difficulty shifting similar to some others posted here on the boards. So, I am going to bleed my clutch and change my transmission fluid to see if I get any improvement before going to a shop to have the master and/or slave cyl. examined.
My question is, I checked the fluid level in the reservoir and when I pulled the cap off there was a sort-of bladder stuck to it, then it popped loose from the cap. Do I place this bladder in the reservoir and fill into the bladder, or am I to fill to a certain level in the reservoir and the place the badder in it.
Bleeding the clutch sounds easy enough, just want to make sure I get the fluid level right on top.
Thanks,
Matt
Old 05-17-2005, 01:17 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Pull it out and then fill the resevoir. Don't forget to leave room for the bladder when filling it up.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 05-17-2005, 02:58 PM
Thank you! I wasn't sure if that bladder was porous and acted as a filter or if was more of a pressure regulating device, or none of the above. Thanks again.
Matt
Old 05-31-2005, 11:18 PM
Vehicle: 2003 Ford F150
It is a diaphram that keeps dirty air out of the fluid. The cap has a small vent hole to not vacuum lock. Without this diaphram, when you depress the clutch it would suck in dirty air into your fluid.
No worries.....
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
