DOT 3 is Correct
I just bled mine this weekend, it says right on top of the fill resevoir.
I too changed my slave about 75K, mines not leaking however the trans. isn't totally disengaging. If I pump the pedal a few times, it helps. That's why I thought it had air in it. I've got 118K now, all city driving. It was suggested to me that it's probably the clutch master cyl. It's been pumped many ,many times in the last 13 years. Seals are probably worn out.
Anyone replace their Hyd. Clutch Master Cyl ? It looks straight forward enough.
