F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-14-2005, 10:46 PM
Vehicle: 1997 Ford Expedition
Unhappy What should I do? Tranny trouble...
Hey all, I've got a '97 Sexpedition w/ 5.4l 4x4, and 3.73 LS rear, 135k mi. The last few days I'm feeling what I think is the trans, slipping. You can feel a lil' jerky while driving. Pretty slight, nothing serious yet. Cant tell what gear specifically, possibly all. Anyway, if this is my tranny going (yes/no?) what should I do? I see Ebay has used tranny's running ~$700-$1k. So, get a used one and pay how much to have installed? Or, how much to have rebuilt? Or... bite the bullet and trade it in while it's still on the road? A car payment'll hurt! Your opinions are welcomed!
Thanks!
The bummer is I've taken good car of it... I have an additional cooler installed, so I have 2 in series, and synth oil!
Old 05-15-2005, 01:08 AM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
well you have a 4r70w transmission with "synth" oil in it. Now you feel the converter slipping. Put mercon V in it!
Alan
Old 05-15-2005, 02:21 AM
Vehicle: 2000 ford F-150
i have to agree... i would add the actual reccomended fluid. if it still feels like its slipping, try some lucas additive in there... my friend used it on his 96 chev and i guess his felt a little stonger with out the jerks.
ERIC
Old 05-15-2005, 03:43 AM
Thanks. That's a new one to me, suggesting reg. ATF vs. Synth. Also, I thought it was a 4EOD tranny... or something like that.
I'm willing to try anything though.
Old 05-15-2005, 10:58 AM
It is possible that you have an e4od, just a little unlikely. Count the pan bolts, 4r70w has 14 and e4od has 20. It was actually the used prices that made me think you had a 4r70w because picking up an e4 for under a gran is very rare to say the least.
Alan
Old 05-15-2005, 11:56 AM
Oh, swell. Well, I'll try a flluid/filter change today, see if that helps. I guess that's the first step before replacing it!
Old 05-24-2005, 04:24 AM
Vehicle: 2005 Ford Mustang
The 97 Expy with a 5.4 will have the E4OD/4R100, that yar is before PWM, which at least eliminates one problem. you won't hurt anything by doing a fluid swap, it may help. Do you have any 'shudder"?
G
Old 05-24-2005, 02:47 PM
Vehicle: 1997 Ford Blown Expy
1997 E4OD specifies Mercon.
1998 and up specify Mercon V.
Not 100% sure why they changed the specification.
Depending on the maker of the fluid, they may or may not be interchangeable, as I understand it. Some folks say go with Mercon V, others say don't. I don't.
If you are running Mercon V, try running the spcified Mercon instead.
I've had zero problems with Mercon, and I tow a heavy boat as well. Have almost 120K miles on her right now...
2007 Dodge Ram 2500 4x4 | CrewCab | Long Bed | 5.9 Cummins HO | First time I've been without a Ford truck
Old 05-27-2005, 07:41 PM
Unhappy
Well, I did change the fluid (Dex III)... it is the E4OD. It did help. In fact I didn't notice anything abnormal for about a week. But today I did notice what is a slight shudder while driving through the gears. Hardly noticable, but it's there.
I suppose I'll just play wait and see.... If it gets worse I imagine a new tranny is in order. I see a few outfits have rebuilt ones for ~$1000. Don't know what installation would be. But since the truck's got 135k mi on it anyway, maybe I'll just get a used one.
Old 05-28-2005, 02:42 AM
Vehicle: 2004 Ford F150
The shudder would be the TC....the torque converters are notorious on these....I think there was a TSB for the sudder
Old 05-28-2005, 10:03 PM
Hmmm, well just a torque converter would be a lot cheaper. How can I tell for sure? It was pretty noticeable today. Anytime you are accelerating, you feel this slight jerkiness.
Old 05-30-2005, 07:55 PM
Vehicle: 1997 Ford F 150
get OEM quality if you rebuild
I would call Jasper. They rebuild transmissions and engines to OEM specs. They are not the cheapest but I know first hand that they stand behind their work.
I had a Ford Taurus trans fail (94/90,000 mi) and the best warranty I could get from a local shop was 90 days. I bought a Jasper unit and they gave me a 75,000 mile "no questions" warranty. I also installed a trans cooler.
Turns out that the speed switch was bad and probably contributed to the trans failure. Yes that's right, it could be a $50 switch causing problems.
Have that speed switch checked out ASAP.
Old 06-01-2005, 02:40 AM
Thanks! I'll see if there's a Jasper near me.... otherwise, I'll be looking for a tranny shop here in the Pac. NW. Or the dealer, I guess.
Old 06-03-2005, 05:28 PM
Vehicle: 1999 Ford F150
You sure the shudder isn't an ignition problem? I had a coil go sour, and it felt like the drivetrain was going to fall out of the vehicle. Being a veteran of the GMC 700R4, I was certain it was the tranny. Never did get a code. Took it to the Dealership and their Diagnostics showed the bad hole.
HTH
Old 06-05-2005, 03:50 PM
I'm not sure of anything.It sure felt like tranny. I 'didnt have any check engine light. We did have a batch of bad gas just distributed here in NW WA state that's been causing problems. I put in a jug of Fuel injector cleaner. The truck's been running fine now for ~ 5 days without a jerk. Maybe that's the cause...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
