Not sure about the door sticker code, but you can always check the pumpkin cover. There should be two metal tags screwed in under your pumpkin cover bolts which will give you information on your rear end.
Jeff
2000 F150 XLT 5.4L 2WD
Black Sport with Flareside
Yokohama Geolander H/T-S G051 (265/70R17)
Ford 17"x7.5" FX4 (Type 15) Aluminum Wheels
PowerSlot Rotors on 4-Wheel Disc ABS
Rancho 5000 Shocks
Factory Tech Valve Body
SuperChips MAX Micro Tuner on "Performance"
Magnaflow Side-Exit Exhaust
Troyer Performance Dual 16" Electric Fans
Troyer Performance Underdrive Pulleys
AirForce One Stainless Steel Intake Kit
