F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-10-2005, 06:31 PM
Vehicle: 1997 Ford F-150
Complete Tranny Fliud Change
I have a 1997 F-150 and I would like to know where is the plug to drain the torque converter? If you got any pictures too that would be great. Thanks
Old 03-11-2005, 12:39 AM
Vehicle: 1999 Ford F150
There's a plate on the front of the trans, facing forward, where the trans. bolts to the engine, that allows access to unbolt the torque converter; remove the plate. Turn the engine over by hand using a socket on the harmonic balance and look for the plug (or have your bride look for the plug while you turn the engine over by hand!) You should see it.
Old 03-11-2005, 04:15 PM
Vehicle: 2001 Ford F150
Actually there is a round rubber cover in the bell housing a little forward of the oil pan. Remove this cover and look up into the hole. Turn the engine using the crankshaft balancer bolt (18mm) until you see the little drain plug line up.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
