In a nutshell...
Whirring noise only while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload, and almost never by bad ring and pinion gears.
A howl or whine during acceleration over a small or large speed range is usually caused by worn ring and pinion gears or improper gear set up.
Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning.
Regular clunking every few feet may indicate broken ring or pinion gears.
Banging or clunking only on corners can be caused by broken spider gears, lack of sufficient positraction lubrication, or worn positraction clutches.
Rumble while turning may indicate bad wheel bearings.
A steady vibration that increases with the vehicle’s speed can be caused by worn u-joints or an out of balance driveshaft.
Clunking only when starting to move or getting on and off the gas might be loose yokes, bad u-joints or worn transfer case or transmission parts.
I hope this helps to narrow it down some, keep us posted.
2004 F250 XLT, CC FX4, V10, LOJACK!!
Engine Mods: Superchip tuner 1714, denso IT16 plugs, Airforce 1 intake, Magnaflow dual sideout exh. Exterior: Sylvania Silverstars, ProComp shocks, Cervinis hood, Street Scene Speed Grill, Painted side mirrors & door handles, 18x10 MB gunner 8 rims, Nitto Terra Grappler 325/60/18s Interior: Alpine HU & speakers, 2 8" Punch subs, Zapco amp, Sirius Sat, Platinum gauge & AC plates, Brshd almnm dash trim, Almnm sills with luminated logo.
