F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-09-2005, 08:13 AM
Vehicle: 1997 ford f150
ring & pinion
just purchased a 1997 f150 supercab with a 4.6l engine. It also has a 3" body lift with 35, 12.5, 17" tires and wheels. Unfortunately gears were never changed. The vehicle currently has 3.55 gears. Ineed help, what gears should I go with?
Old 03-09-2005, 11:23 AM
Vehicle: 2003 Ford F-150
with those 35 inch tires i would say 4.10 or 4.56 with the 4.6 i would say go with 4.56
03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
Old 03-11-2005, 01:24 AM
differentials
Thanks Bigtruck,
Can you help decipher what differentials I have so I can order the new gears. The tag that should be attached to the rear is missing about half of it. The front diff has an 8.8 stamped on the case, I am assuming 8.8 inch. The door tag gives me a code 19 which I believe tells me the current gear set up is 3.55 and I am taking your advice and want to go with the 4.56's to get some power back. Also the front and rear differentials should be identicle correct? so I will have to order 2 of the same?
Old 03-11-2005, 05:52 PM
yes you will need to put the same ring and pinoin gears in both front and back, with the 4.6L engine you have the 8.8 rear end, you will need to order a ring and pinoin for a 8.8 reverse cut IFS for the front and a standerd cut 8.8 straight axle RP for the back, good luck
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
