Quote:
Originally posted by dirtyd0g
I dunno, sounds like maybe the filter came out or something. Did you dent the pan by any chance?
Checked the pan from the outside no damage, I was considering taking the pan off for a inspection to see if anything has come adrift, however I am not sure what bits I need ?? On the underside of the pan it says something like - this pan has a reseable gasket- if this the case then I will have a look, if not I have will have to order the part from the US, which can take 3weeks if all is well...
Not sure If I can drive the truck or not (i use this to get to work)
