Here's a break-down of the (new) names of these trannies:
4R70W:
4 - Four-gear
R - Rear-wheel drive
70 - 700 lb-ft torque capacity
W - Wide gear ratio
4R70E:
4 - Four-gear
E - Electronic
From my understanding the difference in these transmissions is that the crown vics with 4R70E (or AODE, "Automatic OverDrive Electronic") transmission is the same case but different gearing ratios (not wide).
This same breakdown applies to other trannies as well...
4R75W (2004+ models)
4 - Four-gear
75 - 750 lb-ft torque capacity
W - Wide gearing
4R100 (Lightnings, same as E4OD, "Electronic 4-gear OverDrive")
4 - Four-gear
100 - 1000 lb-ft torque capacity
M5OD is still the old-style name, though, which just means Manual 5-gear OverDrive.
Jeff
2000 F150 XLT 5.4L 2WD
Black Sport with Flareside
Yokohama Geolander H/T-S G051 (265/70R17)
Ford 17"x7.5" FX4 (Type 15) Aluminum Wheels
PowerSlot Rotors on 4-Wheel Disc ABS
Rancho 5000 Shocks
Factory Tech Valve Body
SuperChips MAX Micro Tuner on "Performance"
Magnaflow Side-Exit Exhaust
Troyer Performance Dual 16" Electric Fans
Troyer Performance Underdrive Pulleys
AirForce One Stainless Steel Intake Kit
