if you have enough "good" brake line left take a small tubing cutter and loose the bad part..dont use a hacksaw..metal chips...get a adapter fitting at any parts store... tell them what your trying to do they will get you what you need...then put the fitting on the brake line BEFORE you re- flair it and you should be good to go..did the same thing on my old F-250 when i lost the front brake line from the master..hydraulics are all the same..brakes, clutch, whatever...zap! (ford made a 352 ci "fe" motor way back when)
