I dunno on that. Doing the job over and over usually costs more in the long run. I guess it just isn't the way I think things should be done. You need to find someone local knowledgeable enough on that transmission to build it properly. I won't map it all out for you but here are a few tips.
Torque converter.
You want a singleplate unit, your engine doesn't require a dual spring lockup piston,but it should definately be of the 97 up design. The stock front cover is weak, but expensive to replace. If the converter is built with the clutch surface taller than the top of turbine hub you shouldn't have front cover damage so a billet front cover isn't really required.
The fins in the pump are prone to coming loose, you definately want to make sure that piece is brazed or at least welded to secure them in place. Welding the turbine would be a good Idea as well. Brazing is better.
Those engines pull soo much better with low stall converters.
Ok enough with the part that probably confused the heck out of you. What I said was don't cheap out on the converter get someone who knows what they are doing to build it. You don't have to buy a $1000 unit to get a good one. You definately don't want some cheap $150 unit however.
Engine Computer
You need to take this unit out and send it to your ford dealer for updating or replacing. Those PCM's seemed to fail alot and some of them had programming problems.
Transmission Cooler
You need a pretty good size external unit run on the return side of the lines in conjunction with the radiator. Don't forget to flush or replace the radiator. The life of the transmission greatly depends on it's operating temperature.
Transmission
You should have the unit built with many later model components such as steel planetary's in place of the OE aluminum ones. I don't have a whole lot of info for you there. The best thing to do would be to get a Factory Tech unit (IMHO)
I hope that helps
Alan
Edit: The caps lock button is on the left just above the shift key, please turn it off. Thank you
