F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-25-2005, 02:24 PM
Vehicle: 1997 ford f150
Transmission Cooler Question
I have a 97 F150 4.6 2WD and I'm looking for a good after market trans cooler kit. Anyone have a link to find one. I have looked online but just haven't found what I'm looking for.
Old 02-25-2005, 02:25 PM
Oh yeah.....mine didn't originally come with one so I would like to find a kit with the correct fittings etc.
Old 02-26-2005, 02:02 AM
Vehicle: 2002 F150 super crew
Most of the aftermarket kits sold in places like Auto Zone have the hoses and fittings you need to install the cooler.
All you do is open the return line to the trans from the radiator and pipe the cooler in series.
It's an easy matter to use tubing cutters on the return line and hook the hoses to each end and tie wrap back into place.
The only more difficult thing is mounting the cooler.
In no way do I reccomend using the ties supplied with these kits to fasten through the radiator core. There is to much chance of vibration wearing a hole in a radiator tube.
I always custom make metal mountings then use rubber to take up vibration but that' s not a fast rule.
A way to tell which line is the return if you don't know, is to stall the trans when it is cold, for about 45 seconds, after starting a cool engine, then feeling which line is warmer.
The return will be the cooler of the two.
Make sure you put a very small flare on the ends of the tubing and slip the hoses on far enough that thay cannot blow off after the clamps ar tightened because there is still considerable pressure there especially in cold weather before everything get heated up.
Old 02-28-2005, 02:05 PM
This is the one you want...
Sherm....
If you can afford it, this is the cat's meow...
http://www.troyerperformance.com/cgi...3BTransmission
Cheers
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
