Do I have to lie to you?
It only slips when you punch it because that is when you put more power to it than it can take. When these converters fail they either grenade(no movement scrap through the trans) or they just burn the converter clutch up. Yes I think your converter is bad ,but that is not your only issue. If a valve is sticking it is caused by all the material in the fluid. Same goes for the solenoid(which is not your problem) If you doubt what I say drop the pan and cut the filter open.
Alan
