F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-29-2004, 10:39 AM
Vehicle: 1999 Ford F150
Slipping/hard shift when I first start moving.
I have a 1999 F150 4 x 4 5.4 V8, auto. I have noticed before, but more recently, that when I begin moving from a complete stop the truck seems like it is jumping. (Almost feels like something is running into the back of the truck, or kind of like a hard shift) This happens at very low speeds however. I would say it occurs when the truck goes from 1 or 2 mph to about 5 mph.
I thought it may be the transmission fluid so I was going to replace it and the filter. Do you think it could be the transmission being that it is occuring at such low speeds. I didn't think the tranny even shifted until it hit a higher speed. I last replaced the tranny fluid/filter about 50k ago.
Thanks for the info.
Old 01-05-2005, 12:52 AM
Mine does that too. ('94 F-150) I just go real slow at first to get it over with. It has done this for the four years I've owned it. I wish I knew why it was doing that.
Old 01-06-2005, 06:35 PM
U might be letting the clutch out to fast when starting in first. That causes the truck to jump forward and backward a few times.
Old 01-06-2005, 07:14 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
Quote:
It's an auto.
Old 01-07-2005, 11:13 AM
Vehicle: 2001 Ford F-150
Send a message via Yahoo to brahmus
1-2 acctuator spring do a search! my 99 and a friends 99 did the same thing. or put a FTVB!!!
2000 White L Under Destruction!
2002 Silver L Under Construction!
2001 Silver SCREW 4x4 38X15.50R20
Lightning motor, Race Built 4R70W
6lb, Stage II Ported Eaton, all the bolt-ons!
Old 01-07-2005, 11:07 PM
Quote:
Originally posted by dirtyd0g
It's an auto.
Ya ur right my bad.
Old 01-12-2005, 07:25 PM
Vehicle: 1998 Ford F150 4.6
Quote:
Did the search and came up with nothing! Mine is doing the same thing and anymore help/details would be greatly appreciated!
Old 01-12-2005, 11:18 PM
I think he meant 1-2 accumulator. They are prone to breaking springs. The accumulator is located on the front driver side of the transmission and can easily be removed with a pair of snap ring pliers with the pan down.
Here are some accumulator tips
Only use the bonded rubber pistons, do not use the early aluminum ones.
Update the springs to the latest model year vehicle with similar weight. If you have a supercrew get the supercrew setup. I believe it has 1 upper spring and 2 lowers. Likewise if you have a shortbed f-150 yo want the correct setup for it as well. Do not remove the lower accumulator spring on a truck for any reason, the shifts will be abusive.
Alan
If you change the piston change the cap as well. If the piston or cap are hard from age replace them both as a set.
Old 01-13-2005, 09:40 AM
oppsspelling and head were in the wrong place but yes dirtyd0g nailed it!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
