F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-17-2004, 03:44 AM
Location: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Vehicle: 1997 Ford F-150
Send a message via Yahoo to buckdropper
Talking need advise
My wife's explorer a 96 4x4 auto will not go into reverse. It shifts into reverse but will not move its like something is bound up and holding it back. It goes fine forward but is stuck when shifting into reverse. I know its not a F-150 but you guys should be able to help me out here i am sure. Please ring in i am baffeled by this one. I am thinking transfercase, rearend (not hers) brakes ruled out. help a brother out here. I don'e want to crawl under there because we have a s^&load of snow on the ground and i can't move it (she parked it nose first in the driveway grrrr)
Old 12-17-2004, 08:52 AM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
There is a high probability that it is a blown seperator plate gasket on the valvebody.
Alan
Old 12-18-2004, 11:27 AM
Is the valvebody part of the tranny??. thanks allen for any info you can give me. Jim
Old 12-18-2004, 11:34 AM
Yes, you can fix the problem in the vehicle. I have seen alot of epc solenoid problems on the 95-96 models as well. The epc solenoid for those is alone in ford parts and costs about $250. The fix for that is to install a late model solenoid with a transgo shift kit. Email me Dirtyd0gus@yahoo.com and I will get you part numbers of what you need to do to correct it.
Alan
Old 12-22-2004, 01:22 AM
Took the X into the tranny place this morning and when they dropped the pan there was many metal parts laying around.
Final verdict in the morning. 400.00 bucks to drop the tranny and open up for starters. the truck has been good all this time with over 161,000 miles and no rust, looks good and is the higher end XLT with that said i told them to repair it.
Anybody know what a rebuild costs????. 96 X auto 4 speed.
today i am ill, merry f^%kin xmass
Old 12-22-2004, 02:22 AM
To do it right that is an expensive rebuild. Low side 1200 high side 2200
Old 12-22-2004, 05:12 AM
Quote:
Now i am really ill. and with a son unaccounted for.
omfg. F me
Old 12-22-2004, 08:43 AM
Yeah those slushbox's hurt. Now you know why mine has a 5spd.
Old 12-28-2004, 09:01 PM
After a 2800 dollar quote to rebuild the X i put a used tranny in (risky i know), after getting it in i now have a O/D light on any ideas what it couls be??
Old 12-28-2004, 10:57 PM
Did you pull the code? The 95-96 models had some serious EPC solenoid issues and they are high rent. You should install a 97 up EPC Solenoid with the trango shift kit to blow off the excess pressure from the new solenoid. Did you get a transmission that was a 95 or 96? 97 up units changed alot and will not work.
Alan
Old 12-29-2004, 02:53 PM
Its from a 96 so they told me. It seems to be okay now no lights only time will tell. Thanks dirtyd0g you are a great help on this site to us all.
Old 12-29-2004, 07:02 PM
I think what you have is a case of the truck needing to relearn. You really should have a dealer or other shop with a proper scan tool reset the pcm. Disconnecting the battery does nothing for those trucks. I have had that problem before on them. Over time the vehicle will learn to it's new settings so it probably isn't worth messing with now. Glad you got it fixed.
You're welcome.
Alan
Old 12-30-2004, 07:08 PM
Thanks you da man.
1997 F-150 XLT 4X4 4.6 Shortbed REGULAR CAB, FLARESIDE PACFIC CLEARCOAT GREEN, 5-SPEED. WESTIN NERF BARS, EX-TANG SOFT COVER, BED LINER (FORD). Magnaflow SI/DO with Polished 4" Rolled S/S tips also 2002 toyota Rav4
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
