94 F150 4X4 ,302 E4OD trans shift like shift kit .
When over drive button is off no problem but after a few miles or days trans shift hard in all gear,pull code out 628 (execessive converter clutch slippage)and 629(torque converter clutch circuit fault).Pull code again no problem untill i use overdrive again.
Is there a way to just pull code out of trany only.
Have planty of fluid in trans .I understand this year ford had problems with this trans....Sim
