F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-14-2004, 02:06 AM
Will not shift into 4W Drive
I have an F-150 with the 4WD shift switch on the dash. When I turn on the ignition I do not get the 4WD lights do not cycle, nor do i hear the shift relays click in the dash. Switching the dash switch will not switch it into 4WD. I have droped the the switching motor out and tested it and it runs fine. I have also removed the switching relay and jumpered the contacts for the switching motor and it will go into 4WD and light the dash light. The dash switch has 5 volts running to it. I'm stumped at this point. Could it be the GEM? ...Any help please....
Old 12-14-2004, 12:39 PM
Vehicle: 1998 Ford F150
Re: Will not shift into 4W Drive
Quote:
It could be the GEM or even worse, electrical short. There is a TSB regarding this. For a shift on the fly to engage there are like 5 or so inputs it needs. Inputs from the brake switch, Neutral safety switch, speed sensor, ignition switch and one other I believe. They all send signals to the GEM which reads a signal from the switch which in turn sends a signal to the shift motor.
Old 12-19-2004, 12:08 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Check fuse #23 in the Central Junction Box. Inside cab left side of instrument panel.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
