codes
Thanks for the help....I have noticed that the trans shifts and operates normal at low speeds (non-highway). Only after driving on the freeway (approx 2000 rpm@60mph) for a while I notice a change in the feel of the trans (slight vibration) and then the OD light will blink. After that, the shift pressure seems to increase when the trans upshifts through the gears. Turn off the car, start it up again and the OD light is off and the shifting is back to normal until I operate at freeway speeds again.
I received some info (written by Jerry) from the guys at SCT regarding suggested changes to the trans section of the PCM when using a higher stall converter. One function is the "RPM FOR FAILED SPEED SENSOR". Raising the RPM (approx 30 pct) is recommended. Also, adjusting the "LOCKUP SCHEDULE" for the torque converter so it locks earlier (at the 1-2 shift) and dont let it unlock when accelerating.
Any thoughts???
