F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-06-2004, 03:26 PM
Vehicle: 2003 Ford F-150
tranny temp gauge
i just ordered a tranny temp gauge along with coolant temp and air press, my ? is were is the best location to mount the sensor to get the most accurate reading, thanks in advance
03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
Old 10-07-2004, 03:25 AM
Vehicle: 1997 Ford F150
There are different opinions on the where the "most accurate" location is, but IMO, I like to know what the hottest the trans fluid gets, so I put mine in the trans OUTPUT line, just before it goes into the rad cooler. This is so I can see how hot the TC is getting... Lets you know when the TC is unlocked as well.
Most seem to like the test port that's on the drivers side of the trans.... You just have to remove the plug and put in the sensor..... Might have to make sure you get a shorter sensor, as I've head that some of them are longer then the length of the port.....
Others like the pan temp.....
Good luck!
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 207,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 10-07-2004, 09:26 AM
Vehicle: 2001 Ford F-150
Send a message via Yahoo to brahmus
I choose the port on the drivers side then hooked up a manual temp gauge to my out line, i only see about a 5 to 10 degree difference between the two. the out line being hotter but i can live with that. The installation was to easy in the port and the wires were just the right length. Make certain if you mount it in the outline that the sending unit is grounded!!
2000 White L RIP
2002 Silver L Under Construction! http://www.nloc.net/vbforum/gen-2-li...urrection.html
2001 Silver SCREW 4x4 38X15.50R20
Lightning motor, Race Built 4R70W
6lb, Stage II Ported Eaton, all the bolt-ons!
Old 10-07-2004, 12:37 PM
thanks for the info, i will prob. use the port on the side of the tranny because of the ease of install, thanks again guys
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
