I cant find this info to save my butt.
I took my 4r70w out of my 97 4.2L 4x2 last weekend, and i bought a new 4r70w from ariel gears... Now mind you i sent them the old tranny so that they would match up and ensure all my electrical connectors would match.
Now the connector on the driver side just rear of the TR/MLPS sensor, what is it? i pulled it out and it looks like a pressure sensor of sorts? can someone identify it?
also, the connector on the tailhousing is the VSS, right? there is also the speedo gear connected to it... Now i dont remember taking a mechanical speedo cable off. Am i just not seeing that cable and i did take it off? i thought the speedo was electronic on this truck, therefore i souldnt have the mechanical output?. Just to explain myself a little better - the VSS sensor pulls out and has the speedo gear attached to it, on the outside it looks like i am supposed to connect 2 connections to it?
Are these 2 connectors different on my 97 than on later model 4r70w's?
Thanks for taking the time
Justin
__________________ http://www.f150online.com/galleries/...w.cfm?num=9489
97 F150 XL 4.2L
4x2 (Does have a new Traclok and 4.30's)
265/75/16 Yokohama A/t's on Stock Rims
315/75/16 ProComp M/T's on M/T Classic Locks will be here this week
