Noticed this the other day when rotating my tires. I'm not much good on tranny or differential problems. Anyone got any ideas? I tightened up the differential bolts.
Looks like, and hopefully it is, just a bad seal. I would remove, and replace with a new seal. Wash the oil off and keep an eye on it for a few days. I had that problem too, and it never came back.
I am thinking that is it because it is right where the seal leaks and it is in the rear of the diff. Typically if oil is in the front, it is something else. Pretty easy and cheap fix if that is it.
Anyone else have any other insight of what it might be?
Check the little "junction box" for the rear brake lines that is mounted on the differential. If your sway bar has hit it (or anything else for that matter) you could have a leak there.
The rubber brake hose feeding the junction could be cracked as well.
I hope you are lucky and it is just the differential seal. Check it out and let us know what you find...
Account Suspended For Violation of Terms of Service
Vehicle: 1994 ford f-150
duh how stupid can u be? it has to be a bad seal, and you do have to fill it back up with fluid when doing so, because theres fluid that comes out, so u have to replace it, and if it requires some sort of friction modifier, u should add that too. that is unless u want ur rear end to sieze up
Location: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Vehicle: 1997 Ford F-150
Quote:
Originally posted by piperc duh how stupid can u be? it has to be a bad seal, and you do have to fill it back up with fluid when doing so, because theres fluid that comes out, so u have to replace it, and if it requires some sort of friction modifier, u should add that too. that is unless u want ur rear end to sieze up
Dude you really need to relax here, if you can't help with something positive don't post. A whole 8 posts and your insulting folks... get real bro.
1997 F-150 XLT 4X4 4.6 Shortbed REGULAR CAB, FLARESIDE PACFIC CLEARCOAT GREEN, 5-SPEED. WESTIN NERF BARS, EX-TANG SOFT COVER, BED LINER (FORD). Magnaflow SI/DO with Polished 4" Rolled S/S tips also 2002 toyota Rav4
