F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-26-2004, 01:18 AM
Vehicle: 1998 FORD F150
Send a message via AIM to BLUEWORKHORSE
A Question
HOW MUCH WORK WOULD I NEED TO PUT INTO MY TRUCK TO TRANSFER IT FROM 2WD TOO 4WD. IM NOT TALKING PUSH BUTTON IM TALKING FLOOR SHIFT
BEN
Old 07-26-2004, 08:45 AM
Vehicle: 2002 ford f150
honestly, way too much. any articles i've seen on it have said that it takes too many parts to do, on that's on older ones. a new one would be ten times worse. you'd end up with a 4x4 that cost twice as much and was worth nothing because no one would buy it from you.
i would just go buy a 4x4 if that's what you want.
Old 07-27-2004, 02:34 AM
Vehicle: 2001 Ford F-150
i have heard of people converting to a solid front axle with leaf springs that would be the easiest route to go other then buying a 4x4. but there will be alot of fabrication and welding to do.
Old 07-27-2004, 11:37 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
The 4x4 and 4x2 frames are different. Sooo you will need to purchase a 4x4 frame. The munting points for the lower control arm are closer inboard on the 4x2. There is no provision for mounting the front differential. A solid axle would be the easiest and that in itself would be a royal PITA! No to say don't do it but let us know which way you want to go.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, P-1SC Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 08-03-2004, 05:02 PM
I PROBALLY WONT DO IT BUT I HONESTLY THOUGHT YOU WOULD HALF TO CHANG OUT THE SUSPENSION AND THE DIFFERENTIAL BUT IF ITS MORE THAN TAHT TOOO MUCH FOR ME TO HANDLE. ILL JUST HAVE MY BROTHER KEEP PULLING ME OUT WITH HIS JEEP WHEN WE GO 4 WHEELIN
1998 F150 XLT 5.4 Bright Blue 2wd Loooooong Box 285/75/16 tires, Pioneer CD Player. True Duals with Magnaflows, Rally Bar, Access Bed Cover, Custom Tinted tail lights. Ben Says "Its A Long Way To The Top If Ya Wana Rock N Roll" :thumbsup:
Old 08-04-2004, 06:32 PM
Send a message via AIM to Red00Lariat
Sell your truck and buy a 4x4, you would still save money over doing a conversion.
2000 Chestnut Lariat 4x4 SCab, Rhino liner, Rancho RS 9000x's, EBC pads, EBC sloted rotors 20% tint, AEM Brute Force intake, Magnaflow exhaust, hi flow cats, y-pipe,& headers, SCT 9100 w/Troyer tunes, 180 degree t-stat, walbro 255 pump, 24lb injectors, Lightning MAF, ported TB & elbow, NGK TR5's, and pulleys.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
