F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-14-2004, 02:36 PM
Vehicle: 1992 ford f150
can anyone help with codes?
i had what felt like a transmission problem* with my '92 f150 about 2 weeks ago and i took it to a shop where they said that there were a couple of codes that the computer spat back. the codes are - 629 (torque converter?) and 634 (manual lever pos sensor?). the shop called the next day to say that they found these error codes and went to replace the parts indicated but before that they checked the wiring in that area and found that there were dirty connections so before getting into the parts, they cleaned the wires and their connections and tested the truck. it ran fine and continued running fine until yesterday when it gave me the same problem (described below).
can these parts be replaced fairly easily? i'm thinking of going about myself.
* while slowing down to come to a stop at a traffic light, the truck started idling uneven and ridiculously low. it also felt like it was "bucking". i made it to my destination but after shutting the truck off, restarting it and then trying to put it in drive, it just cut off. this happened for the next three times. it would start and as soon as i dropped it into drive it would die. in order to get it going, i had to drop it into first gear then second and then finally i could put it into drive and as long as i didn't stop it was alright.
i'd appreciate any help with this problem.
lsjr
Old 07-21-2004, 05:34 PM
Vehicle: 1999 Ford F150
Ooops! Didn't notice the year.
As Rosanna Rosannadanna said, "Never mind!"
Good Luck!
Old 07-21-2004, 06:36 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
The mlps probably needs to be updated the kit will cost about $100 from ford they are a known problem.
That is why ford revised the part.
The torque converter lockup piston is another known problem.
The early(pre97) design was riveted together and the rivets would loosen up allowing lockup pressure to bleed through them.
The new revised part is one piece and has no rivets to loosen up.
The torque converter can and will cause this problem.
Old 08-11-2004, 07:46 AM
Vehicle: 1990 Ford XLT
MLPS Adjustment?
I'm about to replace mine (mpls) and was wodering if there is any adjustments that need to be made to the shift linkage or something else after you install it?
- dom -
1990 F150
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
