F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-08-2004, 01:29 PM
Vehicle: 1997 Ford F250
E40D leak
Blast from the past!
I noticed this post from 1999 which describes my situation well. I own a 1997 F250 4x4 Supercab with 66K miles. I have transmission fluid leaking out of the black grommet on the flywheel inspection cover. This began following transmission service by a Ford dealership. The leak varies from one drop to a small pool the size of a half dollar each day.
Following the transmission service, I proceeded to haul four heavy twin axle trailer loads 250 miles with empty backhauls. The truck performed well and continues to perform well.
Checking the transmission fluid cold on a level surface indicates that the transmission was overfilled when serviced. I have not added any transmission fluid and have been monitoring the level.
Do I have a problem? Do I need to wait this out until the transmission leaks to the appropriate level?
Here is the link to the 1999 post. Thanks in advance for your qualified feedback!
E40D Leak
Old 07-09-2004, 04:38 PM
If it was following a transmission service, you should check to see that the torque converter drain plug is properly installed. Otherwise, it sounds like the front seal on the transmission.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
