F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-27-2004, 01:20 AM
Vehicle: 2004 Ford F150
trans pan drain plug
Anybody know the drain plug size for the 4x4 transmission pan?
Old 06-27-2004, 01:41 AM
Vehicle: 2004 Lariat Screw F150
F150 Transmission Oil & Filter Change
Work performed on a 1998 Ford F150 4x4 with 4.6L V-8, 4R70W 4spd electronic automatic (code U in doorjamb)
Follow these instructions at your own risk.
Tools needed for the job:
Safety glasses
Rubber gloves
Ratchet, extension, and 10mm, 11mm, 18mm metric sockets
Jack stands or lift (for non-4x4)
Cleaning solvent
Drain pan
Funnel
Rags
13 quarts Mercon V transmission oil (I used Castrol - part synthetic) DO NOT use Mercon or Dextron III. They are not interchangeable.
Filter Kit (Fram FT1167) which comes with a gasket which you don't need.
Flashlight or work light
Note: wear safety glasses while under the vehicle for eye protection as there's lots of dirt and grime under there just waiting to drop into your eyes.
Procedures
Here's a picture of the Ford 4R70W transmission pan with the gasket sitting on top. The OE gasket is re-usable and is stamped as such shown by the red arrow on the right side of the picture below. Notice the grey colour donut magnet shown by the arrow on the top left of the picture.
Wait until the vehicle has cooled off for at least 1/2hr if you've just driven it to avoid getting a "hot oil treatment"... burns hurt!
Remove the rubber inspection grommet (1 1/2inch diameter) between the engine and the transmission in the bottom of the bell housing. Use a flathead screwdriver to pry it out - not difficult.
With an assistant under the vehicle looking into the inspection hole with a flashlight or worklight, use the 18mm socket & wrench to turn the crankshaft pulley (by the radiator) to turn the engine (clockwise). In the inspection hole you will see the torque converter. Have your assistant stop you turning the engine when the 11mm drain bolt is visible in the torque converter. You can do the procedure yourself but it is a lot of climbing under the vehicle and back to turning the crank pulley until you find the plug.
Place your drain pan under the inspection hole and remove the drain plug out of the torque converter with an 11mm socket and extension. The oil will pour out slowly... in fact it may take a couple hours to fully drain the torque converter. It is estimated that it holds almost half of the transmission fluid capacity or around 6 quarts.
Replace the drain plug and tighten securely but do not over-tighten. Some people like to use locktite on the threads to prevent it coming out. This is difficult unless you let it drain overnight so you can clean off the plug and dry off the threads in the torque converter. If fluid is still dripping out it will be difficult. It's optional! Ok, then after tightening the plug, replace the inspection cover.
Loosen all the bolts holding the transmission oil pan on. Carefully remove the bolts by one corner of the pan. Carefully pry the pan down at that corner with your drain pan underneath. There will be fluid going everywhere. Try to get a drain pan that is at least 18 inches wide.
Keep removing the other bolts but leave them loose on one edge to hold the pan up. Tilt it more to get more oil out. Once half of the oil is drained hold the pan back up with an assistant if you have one and remove the rest of the bolts while your assistant holds the pan up. Then carefully drop the pan (without spilling fluid all over yourself) into your drain pan. Drain it.
Using rags or paper towels and solvent clean the interior of the pan and carefully remove the sludge from the pan magnet at the bottom. There is a metallic film on most of the pan surfaces that will wipe off.
Note the position of the OE filter, pull it off and replace it with the new one, make sure the old rubber seal comes out too. Pop the new filter in place of the old one in the same position. Use clean rags to clean the gasket mating surfaces on the pan and the transmission. The old gasket is re-usable. Place the pan back up onto the transmission. Hand-tighten all the bolts.
If you have a torque wrench use it to make sure you don't over-tighten the bolts.
Using a long funnel fill about 5-6 quarts into the transmission through the dipstick tube. You'll need a small neck funnel.
Start the engine and run it for 30 seconds.
Fill another 4 or 5 quarts.
Start the engine again and run 30 seconds.
Inspect level with the dipstick.
Fill more oil up to "full" mark on dipstick.
Drive it around the block and again check the oil level.
You're done.
There will remain about 1 or 1 1/2 quarts in the oil cooler and hoses which can be blown out with compressed air if you so desire but the hoses will have to be removed so most people don't bother. It's also difficult if you don't have compressed air handy.
When you start the engine the hydraulic pump in the transmission fills up the torque converter. You don't want to overfill the transmission right away as 13 quarts won't fit in it while the engine is stopped because the torque converter is empty to start with, that's why you have to start it up a couple of times, otherwise you may blow oil out the vent tube and/or blow some seals.
If you accidentally overfill it, the easiest way to get some fluid out is to drain some from the torque converter. Then you won't have to touch the pan bolts.
Procedure on V-6 and EOD or 4R100 automatic transmission will differ slightly with different sized sockets and different oil. Check your transmission oil dipstick. Most Ford truck automatics went from Mercon to Mercon V during the 1998 model year. Early models got Mercon and the corresponding dipstick. Apparently Mercon V can be run in a Mercon transmission but don't run Mercon in a Mercon V transmission.
If you find a little plastic plug with a rubber o-ring, don't worry, this was in the dipstick tube while the engine was assembled on the assembly line and falls into the transmission pan. It's not a broken or missing part! Discard it or keep it as a souvenir.
Mine took just a hair over 12 quarts. Capacity if the transmission oil cooler/lines where empty as well is listed at 13.5 quarts.
Cost (CDN$):
13 Quarts Castrol Mercon V semi-synthetic $4.88/qt for $63.52
Trans filter kit $39.54 (with gasket that isn't needed)
your time $? - approximately 4 hrs for amateur.
Many transmission shops do a "power" fluid change by hooking up to the cooler lines and doing a pressure fill/exchange without dropping the transmission oil pan. This isn't the best since you have old fluid mixing with new, and you haven't changed the filter. As well the magnet in the pan won't get a cleaning and won't work as effectively to catch metal sludge/particles out of the oil. Think of a power flush as taking a shower, then putting your dirty clothes back on. Not exactly ideal.
Do it yourself, then you'll know it has been done right!
This article has been generously donated by Peter Ferlow.
Old 06-27-2004, 01:53 AM
I need to know the size of the drain plug, not how to do the change. I have a friend who had his drain plug fall out of his truck because he didnt tighten it.
Old 06-29-2004, 01:37 AM
Vehicle: 1999 f150 5.4 xlt
Most factory pans don't have drain plugs.
you could lay under the truck and try a selection of wrenches and see what fits.
Old 06-29-2004, 10:57 AM
Quote:
[i]you could lay under the truck and try a selection of wrenches and see what fits.[/b]
Quote:
Its difficult to lay under the truck with a wrench and see what fits when there is no plug there.
Old 06-30-2004, 01:16 AM
Vehicle: 2000 Ford F150
Good information on changing transmission oil, but what would the torque specs on the pan bolts?
Old 03-25-2006, 03:18 PM
Transmission Fill-Tube Plug
As my screen name indicates, I own a V6 F150. Upon opening the transmission oil pan for the first time ever I noticed a tan colored dart-shaped plug with an O-ring around the pseudo-hollow tip. Confused, I searched online for a diagram that might explain where this piece belonged to no avail.
I called my local Ford dealership and the parts department confirmed it is the plug placed in the assembly line when the truck was being built to avoid dirt from falling inside. Instead of removing the plug when they install the fill tube (where the transmission oil dip stick goes) they just push it through so you can remove it yourself and throw it away upon noticing it durin gthe first transmission oil change.
I don't know if this is what you may have confused to be the transmission oil plug, but this part threw me for a tail spin (I almost bought the Haynes manual, can you believe it?). The dealership said they've received many calls like this, but not to worry about it. Just throw it away. I've scanned the part and uploaded it to show you a visual in case there's any question/ doubt. I hope this helps. If not, that happens and I certainly don't know everything (or anything, for that matter, right?). Good Luck!
Old 03-25-2006, 10:16 PM
Vehicle: 1999 Ford F150
Quote:
What year truck and what is the transmission model?
There are kits available to modify transmission pans that did not have drain plugs.
http://www.etoolcart.com/browseprodu...it-T-3020.HTML
Old 03-26-2006, 12:46 AM
Vehicle: 2001 Blown SCrew
Welcome
That little piece is a plug that is pushed out at the factory and lands in your pan. It is only there for assembly purposes and serves no purpose afterwards. Since it causes no harm, it is left to float around until some unsuspecting owner finds it and says OMG! what is that
Toss it and forget it
5.4L 4.10 Gears
Supercharged by Procharger 12psi
3 Core Intercooler
MAD intake elbow
Flex-A-Lite EFans
FTVB
TROYER TUNED XCAL2
42# Ford Racing Injectors
90mm Ford Racing MAF
Walbro 255lph fuel pump
Wideband A/F ratio guage
Gibson 3" catback SISO
Flexalite E Fans
Troyer Active TransCooler
BFG AT/KO 33" on 18" Lightning Wheels
Rear rollpan and slick license plate bracket
Tons of Chrome, Flames, and Lightning Stuff!
Old 03-26-2006, 12:52 AM
Quote:
9 to 11 ft. lbs per ford factory Service CD.
Old 03-26-2006, 12:55 AM
Most trucks have no drain plug. Go to NAPA and buy the B&M drain plug kit. Fool proof and bullet proof. 5 minute install when pan is off. Just be sure to locate it properly to not interfere with the filter or valve body.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
